Powerbulge grille fitting
dlgis
#1 Powerbulge grille fitting
Post by dlgis » Mon Jun 06, 2022 3:33 pm
I’m having trouble with this, do the 2 bottom lugs fit below or above the metal bar arrowed in the photo below? If they fit below it looks like the grille will interfere with the closing lip on the bulkhead. And there’s no way it will go above the metal bar. Not sure it the bulge has an incorrect profile or it the aftermarket (Martin Robey) grille is the wrong shape? The bonnet hasn’t had a grille since it was made up several year’s ago. :scratchheadyellow:
Darryl
#2 Re: Powerbulge grille fitting
Post by DWW » Mon Jun 06, 2022 4:05 pm
Is your bonnet the original that came with the car, I know that on some replacement bonnets the bracket that fixes that grill was welded the wrong way round and causes the grill to protrude further than it should.
tim wood
#3 Re: Powerbulge grille fitting
Post by tim wood » Mon Jun 06, 2022 4:56 pm
I think the grille bolts in from below, mine certainly does.
dlgis
#4 Re: Powerbulge grille fitting
Post by dlgis » Mon Jun 06, 2022 5:08 pm
Hi Danny, no it’s a replacement that the guy who restored the car about 7 years ago made up from a mix of new and old parts (I think ?) so we have had to do some work to it when fitting the new radiator and stoneguard. This may well be due to the quality of replacement bits. There are no holes currently to fit the grille so we’d need to drill those and if fitted it looks like the shape of the grille would push up the centre of the powerbulge metalwork if the locating screws were fully tightened. The bulge is also wider than the grille itself by quite a bit :questionmarks:
Darryl
#5 Re: Powerbulge grille fitting
Post by DWW » Tue Jun 07, 2022 5:38 pm
This is a case requiring a creative solution…..😁
dlgis
#6 Re: Powerbulge grille fitting
Post by dlgis » Tue Jun 07, 2022 6:11 pm
Aha - fits in the same category as fitting a Rob Beere reaction plate, a sump plug or a Marston copy radiator then :lol:
Darryl
