Redman
Post
by Redman » Mon Oct 02, 2023 12:01 pm
Gordon James
S3 1971 - Original (JHT) LHD/Auto/Air Con. Re-imported from US via UK in 1994, rebuilt Antwerp. Dk Blue (orig Sable)/Biscuit (orig Beige)
Porsche 911SC 1983
VW T2A Bus 1971
VW Beetle Cabrio 1967 (but bit of a mixture!)
Redman
Post
by Redman » Mon Oct 02, 2023 6:19 pm
Erratum! Some of them look reasonable, some do not (if you can see through all the crap that's on the electrodes)....
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
71 V12
Post
by 71 V12 » Mon Oct 02, 2023 8:53 pm
Not wishing to state the obvious, but looks like there has been a coolant leak in that area!
Redman
Post
by Redman » Mon Oct 02, 2023 10:49 pm
Or would you say water getting through bonnet vents and settling in spark plug cavities? The car has no rain covers installed on top of the engine. Nevertheless, would coolant produce this reddish residue? ATM certainly it is green antifreeze not orange.
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
Post
by abowie » Tue Oct 03, 2023 4:28 am
Redman wrote: ↑Mon Oct 02, 2023 10:49 pm
It's rust from those plugs being in water in the divots in the head.
PO probably washed the car then put it away.
Redman
Post
by Redman » Tue Oct 03, 2023 4:44 am
If it is coolant, I'd be surprised - engine gives no sign of head gasket issues (and I had a similar LR V8 that overheated multiple times and I had to replace the head gasket twice which included helicoiling the block to get some new studs in). But I must admit @71V12 it does not look like rust, more like chemical residue. Fingers crossed it is just water getting in and sitting there. Having replaced the plugs (and cleaned out each plug well to the best of my abilities) I'll pull them after a while and see what results. Finally, anyone any comments on the NGK BPR6ES (gapped at 0.6mm).
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
Post
by chrisfell » Tue Oct 03, 2023 7:26 am
I once owned a CZ motorcycle that ate its spark plug. There was only one and when the central electrode had worn so far it would no longer spark the engine died. So I carried a spare two plugs with me at all times. This was not a unique phenomenon. Early Kawasaki triples also had an appetite for plugs. They even had threaded holes in the frame under the seat to carry spare plugs.
Post
by MarekH » Tue Oct 03, 2023 3:33 pm
All of the orange stuff looks pretty external, so I'd also be relatively relaxed about that. If you are on choke for a long time, it implies some of the carburettors are too lean at low load. If the plugs are sooty and it isn't after a nice long run, then that may also be from your choke enrichment.
Redman
Post
by Redman » Wed Oct 04, 2023 5:24 am
Thanks for that reassuring comment, Marek. I took the car gir its first run with new plugs yesterday: immeasurably better. Came off choke so much quicker, plus running noticeably more smoothly (why am I not surprised). I had been planning to pull the plugs after 500km or so and see condition. I take your point about needing to think about excess choke disguising real carb settings (lean/rich). I will try to stick to longer runs to help avoid this - but I never take the car out for less than 30 min runs avoiding traffic and make sure well up to temperature. Thanks all.
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
Redman
Post
by Redman » Fri Oct 13, 2023 2:28 pm
200 km later......on a good fast trip, plus took the advice of others on this forum and added some good quality 2 Stroke oil to the tank. Result is a clean clean plug (this one is 6B; I'll try 6A next time I check). Engine is running very well indeed. No comparison with what was going on before. Thanks all.
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
jagwit
Post
by jagwit » Thu Nov 02, 2023 8:46 am
Redman wrote: ↑Fri Oct 13, 2023 2:28 pm
Interesting!! I'm a big fan of 2SO in old engines as well! Pity you did not measure compression before and after adding 2SO. That might have been interesting too!
Best Regards
Philip
Post
by bitsobrits » Thu Nov 02, 2023 11:58 am
Coking up an engine by burning a 2SO mix could certainly raise compression, but why would you want to do that?
jagwit
Post
by jagwit » Thu Nov 02, 2023 12:03 pm
bitsobrits wrote: ↑Thu Nov 02, 2023 11:58 am
2SO
DE-COKES a non-cat, non O2-sensored engine.... among many other advantages.
Best Regards
Philip
jagwit
Post
by jagwit » Thu Nov 02, 2023 12:43 pm
jagwit wrote: ↑Thu Nov 02, 2023 12:03 pm
2SO
I'll elaborate:
Using two-stroke oil (2SO) as an additive (approx 200:1) on a non-cat, non-o2-sensored petrol and diesel engines does many good things, the main ones being:
- softening and eventual removal of the carbon deposits that build up on the inlet and exhaust valves
- softening and removal of carbon deposits on the piston crown
- softening and eventual removal of the carbon build-up between and behind pistons and rings which could cause the rings to jam in the piston and thus not seal properly resulting in optimal compression over time
- lubricating carburetor moving parts
- showing fuel leaks - petrol evaporates but leaves blueish 2SO oil
- preventing rust in steel fuel tanks and fuel lines (fuel evaporates but 2SO remains)
Have a look at this YT video:
https://www.youtube.com/watch?v=QLW5KEslF3A. He runs a 40:1 and a 4: 1 ratio. Compression also happen to go up by 5% .... Note the oil deposits which remain. This is what softens the carbon.
I just chuck 500ml in with a tank fill every now and then - when I remember.
Best Regards
Philip
Post
by chrisfell » Thu Nov 02, 2023 1:49 pm
Two stroke oil in a four stroke?
Nah! Not a good idea.
Of those "benefits" listed above, most are imagined.
If you have carbon on the valves or pistons using today's petrol, the engine is running rich. Adding oil to the petrol will not improve that. If you have carbon behind the rings you have a worn cylinder.
Lubricating a cylinder will usually increase the compression ratio, compared to a dry test.
Feel free to watch any number of videos on the interweb, but please forgive me if I say I think this one is a load of old tosh.
Post
by bitsobrits » Fri Nov 03, 2023 12:55 am
jagwit wrote: ↑Thu Nov 02, 2023 12:43 pm
Perhaps if the companies who designed, built, and warrantied these and similar 4 cycle engines over the last 60 years recommended adding 2SO to the fuel, then I might do so. But as they didn't, I'm not.
And if your are looking for interesting YT videos, you might want to check out the magnetic fuel savers:
https://tinyurl.com/Fuel-saver-video
Post
by Series1 Stu » Fri Nov 03, 2023 9:54 am
modern day snake oil!
Redman
Post
by Redman » Fri Nov 03, 2023 4:41 pm
Well will have to see. As long as it does no harm, I'm willing to give it a try.
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
Allrand
Post
by Allrand » Sat Nov 04, 2023 10:50 am
Those things come from the 60's, were tested by the AA & other institutions and were never proved to be of any benefit.
Randall Botha
MontanaDiver
Post
by MontanaDiver » Wed Nov 08, 2023 3:01 pm
This was my first impression of the situation. That the rain shields were not in place. I removed mine several years ago, because it covers so much of the engine when I am at a car show. I don’t every wash off the motor for fear of getting standing water in the plug wells.
Dennis
74 E-type OTS 5.3 EFI HE Marelli V12 4 speed
1990 Jaguar XJS V12 convertible donor car
Great Falls, Montana
