Oil pressure sender thread size
andrewh
#1 Oil pressure sender thread size
Post by andrewh » Tue Sep 17, 2024 4:24 pm
Good evening chaps. I am trying to establish the thread size of the oil pressure sender unit as I have purchased a 100 psi gauge which comes with a new confangled sender which has a 1/8 NPT thread. Therefore I will need to find an adaptor to connect the new sender to the block. I have a theory on the thread, but I am interested to see what others can tell me. thanks in advance.
1962 3.8 Series One FHC
#2 Re: Oil pressure sender thread size
Post by mgcjag » Tue Sep 17, 2024 4:39 pm
1/4 BSPP.. But have a look at this thread there is a photo with thread sizes....Steve viewtopic.php?f=3&t=20216&p=164191&hili ... ad#p164191
mtnjag
#3 Re: Oil pressure sender thread size
Post by mtnjag » Wed Sep 18, 2024 12:09 am
Doesn't look like you want to follow the example of how to connect though.
That shows a BSPT (tapered pipe thread) adapter going into the filter body that has a BSPP Parallel thread.
Good reference for thread sizes.
Layne
Car #876005, 62 OTS
#4 Re: Oil pressure sender thread size
Post by mgcjag » Wed Sep 18, 2024 6:27 am
Hi Andrew you can get a correct adaptor from Merlin motor sports....iv fitted one....Steve
andrewh
#5 Re: Oil pressure sender thread size
Post by andrewh » Wed Sep 18, 2024 7:17 am
Thank you chaps. On the case this morning. I actually have Car Builder Solutions near me and they list some adapters. 🙏
#6 Re: Oil pressure sender thread size
Post by Series1 Stu » Wed Sep 18, 2024 1:32 pm
Hi Layne
It's acceptable and common practice to use a tapered BSP male thread in a parallel female thread. Sealing isn't an issue. However, it is not acceptable to fit a parallel male thread into a tapered female thread.
mtnjag
#7 Re: Oil pressure sender thread size
Post by mtnjag » Wed Sep 18, 2024 1:53 pm
Well, it works to seal, and I know it is commonly done for convenience sake but I'd rather use the proper adapter to go from BSPP to whatever rather than cram a pipe thread into a straight thread that would normally take a sealing washer.
The adapters are commonly available on Ebay, Amazon, or at your local Hydraulic shop as they are used throughout the heavy equipment industry.
Layne
Car #876005, 62 OTS
