MK2 all synchro gearbox swap???
PierreW
#1 MK2 all synchro gearbox swap???
Post by PierreW » Thu Feb 19, 2026 6:07 am
Has anyone ever fitted/adapted a fully synchronized Jaguar MK2 gearbox to replace the Moss gearbox?
Jaguar MK2 1967 since 1980
Lotus Seven 1963 since 2015
XKE S1 1964 OTS since 2023
Norton
Norway
#2 Re: MK2 all synchro gearbox swap???
Post by Norton » Tue May 12, 2026 7:23 pm
Hi.
Think I have read on this forum that someone have done that. But you need another clutch bell housing to fit the all synchro box. A bell housing from a limosine will fit if opening the starter mounting holes. Guess yours is a 3.8 and I think the bellhousing from a 4.2 will fit. All this have to be verified, as I have not. But I do have a bellhousing fron a mk10 4.2 on the shelf. Which I have no use of.
Harald.
#3 Re: MK2 all synchro gearbox swap???
Post by mgcjag » Tue May 12, 2026 8:15 pm
As far as im aware the Mk2 has a long tail section so won't fit in a fhc or ots.....most Mk2s had the long overdrive box.....the non o/d gearbox has a long tail section.....Steve
