Squeaky fornt suspension
pmansson
Sweden
#1 Squeaky fornt suspension
Post by pmansson » Sun Apr 26, 2015 4:54 pm
It relates to my 420G, but this forum is often better than Jag Lovers, hence my posting now:
All bushes are new since about a year. They are all rubber except the ones holding the anti roll bar to the chasis (the 2 central bushes) which are red poly. After about a year of driving, not more than 1000 miles, I now have squeaks when going over sleeping policemen, or braking hard. It came at one particular instance, rather than gradually. It was front left to start with, but now I can hear it more centrally, perhaps even on the right side.
It appears that both new Metalastics and the poly bushes can create this squeaky noise. I am just hoping that it is the poly bushes, which are far easier to remove and smear with more suitable spray, than the rubber buses on the upper wishbones. A lithium spray is what I have in mind, rather than an oil based product.
Any hints to the source of the squeaks....?
Peder
Post by Heuer » Sun Apr 26, 2015 6:41 pm
Polybushes - I had exactly the same problem and ended up going back to all rubber. No issues since. It was always worse in warm and dry weather.
Post by abowie » Sun Apr 26, 2015 11:54 pm
The nolothane bushes will squeak if not greased.
Post by mgcjag » Mon Apr 27, 2015 8:16 am
Hi Padar.....my advice would be to check out with the poly bush manufacturer, if u can to see what u actually have fitted
(assuming they are marked) they do not all work the same......for instance I have replaced all the rubber on my E for the BLACK poly bushes as supplies by SNG Barratts, these are a direct replacement for the rubber and need no greasing/lubrication....and have never made a squeek...there are other makes that have internal sleeves work totally diferently and require lubrication.. hope this helps
KingRichard
Netherlands
#5
Post by KingRichard » Mon Apr 27, 2015 9:24 am
HI,
I also have the Polybush kit from SNG. Never heard a squeek in my life. Very pleased with it.
mgcjag wrote:I have replaced all the rubber on my E for the Black poly bushes as supplies by SNG Barratts, these are a direct replacement for the rubber and need no greasing/lubrication....and have never made a squeek...
E-type series 2 2+2 RHD 1969
42south
New Zealand
#6
Post by 42south » Fri May 01, 2015 10:23 am
The red bushes definitely need plenty of lubricant. I had to take the IRS out to do the upper shock bushes, but it fixed it, no more squeaks.
cheers
Mark Brown
Dave K
Post by Dave K » Fri May 01, 2015 6:53 pm
The reason polybushes or any other type squeak is if you fit them and then tighten them up without running the car for a few miles with the nuts nipped, once everything has settled then tighten them up with the car sitting on the ground not jacked up.
I've never a squeak out of any of mine and my car has poly all over.
pmansson
Sweden
#8 From red poly back to original in rubber
Post by pmansson » Sun Jun 21, 2015 10:52 pm
Thanks for all the replies and lessons learnt. I went back to rubber, and there are no noises at all, in any situation. We?ll see how long they last....
