original item or PO IVR improvement?
mark10337
Switzerland
#1 original item or PO IVR improvement?
Post by mark10337 » Fri Sep 30, 2016 7:21 am
I found the following attached to the 10v Instrument Voltage Regulator (IVR). It is labelled 5MFD 250WV. Is this original? The casing was attached to the thumb screw on the bracket of the oil pressure with the lead going to the 12v B terminal of the IVR.
-Mark
#2 Re: original item or PO IVR improvement?
Post by MarekH » Fri Sep 30, 2016 8:13 am
It's a capacitor to dampen any voltage spikes. They are also present under the s3 dash. I'm not sure whether this is a replacement part or not, as by 1974, those were a large blue plastic can with the manufacturer's name alsom stamped onto them.
I'd just put it back.
JagWaugh
Switzerland
#3 Re: original item or PO IVR improvement?
Post by JagWaugh » Fri Sep 30, 2016 8:17 am
As far as I can tell from the SII parts list, not original, but the scans aren't very good in places.
Period, definitely, I find them all the time in circuits like the IVR. It certainly isn't hurting things, you can leave it in, take it out, or upgrade to an electronic IVR which won't generate any noise (partly because it has caps built in to the casing).
Andrew
mark10337
Switzerland
#4 Re: original item or PO IVR improvement?
Post by mark10337 » Fri Sep 30, 2016 10:31 am
Thanks guys. It's going straight back on :lol:
-Mark
#5 Re: original item or PO IVR improvement?
Post by abowie » Fri Sep 30, 2016 10:50 pm
Not originally fitted.
