Dynamator install in a 3.8
#1 Dynamator install in a 3.8
Post by abowie » Sun Apr 26, 2026 4:57 am
I thought I'd write a little post about installing the Tudor Dynamator in my 3.8 coupe. I'm doing this because it wasn't immediately clear how to do this.
First a word about Tudor. I chose to order the Dynamator from their website, which is in the UK. The price is listed as GBP 199.95, which is the same on their EBay shop.
I enquired if this included VAT, which it does, but they were not willing to discount me the VAT even though I am in Australia. I was vaguely told that the price appears differently if you have a non UK address on checkout; it doesn't.
I ordered one anyway as the postage on their website was less than from eBay, and it duly arrived well packed but without the specifically promised installation instructions. I contacted Tudor by email, and the reply was a link to a diagram on another company's site which was less than helpful.
Fortunately a little Googling turned up this diagram.
I opened the RB340 regulator and removed the 3 coils.
As recommended I soldered in a 40A fuse between the D and B contacts, and I also put in a little skip to take power to the F (for field) coil wire.
Installed, the regulator looks exactly the same as stock, and the Dynamator itself looks pretty much like the original.
#2 Re: Dynamator install in a 3.8
Post by mgcjag » Sun Apr 26, 2026 7:11 am
Hi Andrew....great info....Thanks for posting
#3 Re: Dynamator install in a 3.8
Post by abowie » Sun Apr 26, 2026 8:43 am
Hi Amdrew....great info....Thanks for posting
All good. It surprised me that I couldn't find instructions for doing this easily.
Hopefully this will save someone else the trouble in the future.
#4 Re: Dynamator install in a 3.8
Post by mgcjag » Sun Apr 26, 2026 8:53 am
Hi Andrew...is this a Negative earth set up....I can just see the Neg on the battery on your diagram....Steve..ps just haveing a closer look....the terminals in the drawing are A & A1 and no WL..and the letter sequence dosnt match whats on your 340?
#5 Re: Dynamator install in a 3.8
Post by abowie » Sun Apr 26, 2026 11:56 pm
Yes negative earth. I agree now I look at it the diagram terminals are drawn in a different order. I have wired it to the letters.
#6 Re: Dynamator install in a 3.8
Post by abowie » Sun May 03, 2026 6:02 am
I'm in two minds as to whether to keep the ammeter or not.
I'm going to replace the ammeter with one with the guts of a 50 amp Landrover one which I think should be robust enough.
Otherwise I'll convert to a voltmeter, but I'd prefer to keep it original if I can.
