Dynamator install in a 3.8
#1 Dynamator install in a 3.8
Post by abowie » Sun Apr 26, 2026 4:57 am
I thought I'd write a little post about installing the Tudor Dynamator in my 3.8 coupe. I'm doing this because it wasn't immediately clear how to do this.
First a word about Tudor. I chose to order the Dynamator from their website, which is in the UK. The price is listed as GBP 199.95, which is the same on their EBay shop.
I enquired if this included VAT, which it does, but they were not willing to discount me the VAT even though I am in Australia. I was vaguely told that the price appears differently if you have a non UK address on checkout; it doesn't.
I ordered one anyway as the postage on their website was less than from eBay, and it duly arrived well packed but without the specifically promised installation instructions. I contacted Tudor by email, and the reply was a link to a diagram on another company's site which was less than helpful.
Fortunately a little Googling turned up this diagram.
I opened the RB340 regulator and removed the 3 coils.
As recommended I soldered in a 40A fuse between the D and B contacts
Installed, the regulator looks exactly the same as stock, and the Dynamator itself looks pretty much like the original.
To get the alternator light to work you need to connect the field wire (brown/green) to the wire to the light (smaller brown/yellow).
For the time being I've just done this with a bit of metal but I'll work out a more aesthetic fix on the dummy regulator later.
#2 Re: Dynamator install in a 3.8
Post by mgcjag » Sun Apr 26, 2026 7:11 am
Hi Andrew....great info....Thanks for posting
#3 Re: Dynamator install in a 3.8
Post by abowie » Sun Apr 26, 2026 8:43 am
Hi Amdrew....great info....Thanks for posting
All good. It surprised me that I couldn't find instructions for doing this easily.
Hopefully this will save someone else the trouble in the future.
#4 Re: Dynamator install in a 3.8
Post by mgcjag » Sun Apr 26, 2026 8:53 am
Hi Andrew...is this a Negative earth set up....I can just see the Neg on the battery on your diagram....Steve..ps just haveing a closer look....the terminals in the drawing are A & A1 and no WL..and the letter sequence dosnt match whats on your 340?
#5 Re: Dynamator install in a 3.8
Post by abowie » Sun Apr 26, 2026 11:56 pm
Yes negative earth. I agree now I look at it the diagram terminals are drawn in a different order. I have wired it to the letters.
#6 Re: Dynamator install in a 3.8
Post by abowie » Sun May 03, 2026 6:02 am
I'm in two minds as to whether to keep the ammeter or not.
I'm going to replace the ammeter with one with the guts of a 50 amp Landrover one which I think should be robust enough.
Otherwise I'll convert to a voltmeter, but I'd prefer to keep it original if I can.
#7 Re: Dynamator install in a 3.8
Post by Series1 Stu » Sun May 03, 2026 9:09 pm
I replaced the guts of my ammeter with the movement from TIM Super Dash 60-0-60 ammeter. Was easy enough to do and looks more standard than a voltmeter. Although a voltmeter probably tells you more about what's going on than an ammeter does.
