Valve timing gauge
japomero
#1 Valve timing gauge
Post by japomero » Wed Mar 11, 2020 3:12 pm
Looking for someone who could provide a photo of the valve timing gauge with a ruler in the frame.
Thanks for the help
Jim
#2 Re: Valve timing gauge
Post by mgcjag » Wed Mar 11, 2020 3:41 pm
Hi Jim.... sorry dont recognise the term..valve timing guage....what us it......Steve
japomero
#3 Re: Valve timing gauge
Post by japomero » Wed Mar 11, 2020 3:45 pm
mgcjag wrote: ↑
Hi Jim.... sorry dont recognise the term..valve timing gauge....what us it......Steve
Thanks Steve
It is a flat steel gauge that fits over the end of the camshaft on engine assembly that holds the camshaft in position while the #6 piston is at TDC.
#4 Re: Valve timing gauge
Post by mgcjag » Wed Mar 11, 2020 4:11 pm
Camshaft setting/Timing tool
japomero
#5 Re: Valve timing gauge
Post by japomero » Wed Mar 11, 2020 6:12 pm
Perfect.
Thanks a bunch.
Jim
#6 Re: Valve timing gauge
Post by Gfhug » Wed Mar 11, 2020 8:15 pm
They are readily available to buy for about £10 ($15) so no reason to make an imperfect one from guessing dimensions from a photo if that is your plan
japomero
#7 Re: Valve timing gauge
Post by japomero » Thu Mar 12, 2020 2:33 pm
Great information. Where are they available from?
Jim
#8 Re: Valve timing gauge
Post by mgcjag » Thu Mar 12, 2020 3:09 pm
Jim...google is your friend...just search Jag cam setting tool
Lost Horizon
#9 Re: Valve timing gauge
Post by Lost Horizon » Fri Mar 13, 2020 9:46 pm
And, to round out the thread, here it is in action...
Dana
Late S2 1970 OTS US LHD
keithmac
#10 Re: Valve timing gauge
Post by keithmac » Sat Mar 14, 2020 11:33 pm
Try Browns Lane Jaguar. Canadian E-Type specialist and parts supplier. He likely has them in stock.
http://brownslane.com/
Keith
1967 S1.25 OTS, 1952 MG TD
japomero
#11 Re: Valve timing gauge
Post by japomero » Sun Mar 15, 2020 3:29 pm
Thanks all. The photo was great. Have the drawing done.
Easy cut from 3/16 plate.
Jim
#12 Re: Valve timing gauge
Post by malcolm » Tue Mar 17, 2020 10:36 am
Still wouldn't do that Jim. It may not look it, but the measurements are very sensitive. Little bit out, and engine won't be perfect. Just get one sent from UK if you can't source it.
