Early otter fan switch
poofacio
#1 Early otter fan switch
Post by poofacio » Wed Jun 17, 2020 10:48 pm
This maybe of interest to those who are interested in "original look"
I have after a lot of searching found an aircraft component that fits inside the original switch. It does exactly the same job but is 100% reliable! ( a bit of a fiddle to fit though)
61 RHD OBL DHC
61 flat floor DHC
61 FHC
63 FHC
66 FHC (QUAD LIGHTS)
Geoff Allam
#2 Re: Early otter fan switch
Post by Geoff Allam » Thu Jun 18, 2020 12:26 am
Very interesting. Please post a description of what you have done along with photos of the process.
Geoff Allam
#3 Re: Early otter fan switch
Post by Heuer » Thu Jun 18, 2020 9:47 am
:yeahthat:
Geoff Allam
#4 Re: Early otter fan switch
Post by Geoff Allam » Thu Jun 18, 2020 3:43 pm
Is this the type of switch you are using or have you found something more reliable?
Geoff Allam
poofacio
#5 Re: Early otter fan switch
Post by poofacio » Thu Jun 18, 2020 10:21 pm
I used a switch that is used in eurofighters (so probably quite reliable!) a friend got them for me. I had terrible trouble finding something small enough to fit in the original casing and able to swich enough current. ( not a major problem as it is an OBL car and hence has a fan relay). It requires quite a bit of metal removal from the old bi-metal strip holder, and a deicate soldering job. It switches at 5 degrees lower than the original spec which I consider an advantage!
61 RHD OBL DHC
61 flat floor DHC
61 FHC
63 FHC
