Nylon fuel pipe
lyons
#1 Nylon fuel pipe
Post by lyons » Thu Jan 07, 2021 2:32 pm
Trying to bring car back to original, so has anybody found a supplier for the white nylon fuel pipe.
Obviviously SNG do a kit at a price but surely there is a cheaper supplier off the roll.
Mich7920
#2 Re: Nylon fuel pipe
Post by Mich7920 » Thu Jan 07, 2021 2:34 pm
HI
SNG have it alone by ml, ask them.
Mich
Michel
#3 Re: Nylon fuel pipe
Post by christopher storey » Thu Jan 07, 2021 3:48 pm
Certainly it can be bought by the length - not much help to you but I have bought mine at Jaguar Spares Days. May I offer one bit of advice ? Do not use heat to soften it - it wrecks it . Instead use a lubricant such as WD40, red rubber grease or the like
tim wood
#4 Re: Nylon fuel pipe
Post by tim wood » Thu Jan 07, 2021 7:12 pm
Agree with Christopher, I’m sure I read somewhere that heating the fitting was an answer.
Never tried it though - probably best with no fuel in it !
#5 Re: Nylon fuel pipe
Post by christopher storey » Thu Jan 07, 2021 7:17 pm
Ah, Tim, that's an interesting point that I hadn't considered - it was just that when I was sold it I was told that under no circumstances was I to heat the pipe itself
ysmalkie
Poland
#6 Re: Nylon fuel pipe
Post by ysmalkie » Thu Jan 07, 2021 7:54 pm
I bought it at length from Aston (it was actually not that expensive and I wanted to make sure the quality is OK) but it extended few cm over next 2 days.
I am not sure what will the outcome be.
HOWEVER, on a previous attempt I bought one from an e-bay seller in US and his extended considerably over time AND started to leak like a fine strainer.
So, check what you get... Results in the boot may be terrible.
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
#7 Re: Nylon fuel pipe
Post by mgcjag » Thu Jan 07, 2021 7:54 pm
Heating the fitting with it being held in a vice and pushing on the pipe has been mentioned befor here on the forum quite a few times.....Steve
#8 Re: Nylon fuel pipe
Post by abowie » Thu Jan 07, 2021 10:50 pm
From experience if you don't heat it you'll really struggle to get it onto the fitting.
I have had some success using nylon tube from places that use it for pneumatic/hydraulic actuation. I bought 50m but we have done a lot of cars with it.
To be honest for 1 car I'd be buying it from SNGB.
Mich7920
#9 Re: Nylon fuel pipe
Post by Mich7920 » Fri Jan 08, 2021 12:31 am
I think it's better to heating the pipe gently with a heater gun and puch firmly onto the fighting.
Heating the pipe is easy to control. Heating the fighting too mutch is'nt good for the nylon.
SNG # FS1001
Mich
Michel
Simonpfhc
#10 Re: Nylon fuel pipe
Post by Simonpfhc » Fri Jan 08, 2021 7:07 am
Heating the nylon pipe with hot water also works well. Did that with mine and it allowed me to shape the pipe and attach to fittings much easier. No problems since.
62 3.8 FHC
91 Porsche 928GT
ollieoscarsid
#11 Re: Nylon fuel pipe
Post by ollieoscarsid » Sat Jan 09, 2021 10:19 am
You don’t need to heat it, the pipe can be held in a pair of pipe flaring collets as per pic, if you don’t have any you can make by drilling a 3/8” hole between two steel or ally plates held together in a vice so you end up with something as per pic. Works beautifully, hold in vice with about an inchbpoking out, a couple of taps with a soft mallet and job done. Did a full car set in under an hour for the princely sum of £8.
1963 S1 opalescent silver blue
Robbiee
#12 Re: Nylon fuel pipe
Post by Robbiee » Sat Jan 09, 2021 10:59 am
Is it just me but that explanation has not really helped😂
Could you possibly explain a little more please?
#13 Re: Nylon fuel pipe
Post by mgcjag » Sat Jan 09, 2021 11:08 am
Hi Robbie...makes sense to me......your just useing the collets as shown or something similar to wrap around the pipe and be able to grip it in a vice without crushing it.....Steve
ollieoscarsid
#14 Re: Nylon fuel pipe
Post by ollieoscarsid » Sat Jan 09, 2021 12:21 pm
Maybe it was a little vague. The main problem on assembling the pipes is actually holding the pipe tightly without crushing it, so the banjo can be inserted. The split clamp/collet will hold the end of the pipe nice and tight without any damage/distortion allowing the banjo to be tapped in, it certainly doesn’t need any heat and works very well dry.
It’s also worth fitting one end only and trial fitting to car first and marking the correct orientation of the second fitting (if they’re both banjos) as unlike rubber, the nylon doesn’t take too kindly to being twisted when trying to line up the second end. Sits much nicer too. Hope this helps. Chris.
ysmalkie
Poland
#15 Re: Nylon fuel pipe
Post by ysmalkie » Sat Jan 09, 2021 1:19 pm
Gents, I think you are trying to make rocket science out of something quite simple. :-)
Just heat up the banjo, heat the pipe a little so that it's flexible (50C is enough) and slide it in.
If you overheat the pipe, just cut a bit off.
Tadek
Tadek
Jaguar XK120 OTS
#16 Re: Nylon fuel pipe
Post by Heuer » Sat Jan 09, 2021 1:23 pm
:yeahthat:
Simple, does not distort the pipe or burn your fingers!
265bhp
#17 Re: Nylon fuel pipe
Post by 265bhp » Sat Jan 09, 2021 11:08 pm
Heating only the nylon tube is not the best procedure..it cools too quick...heat both the nylon and the metal banjo fixture...the metal of the banjo retains the heat far longer
Hot water from the kettle and immerse in a mug is fine...I had no problems if I gripped the nylon in my hand and pushed firmly....sometime a bit of extra assistance from a length of 2x2 softwood applied to the banjo was helpful....;)
tim wood
#18 Re: Nylon fuel pipe
Post by tim wood » Sat Jan 09, 2021 11:19 pm
Mich7920
#19 Re: Nylon fuel pipe
Post by Mich7920 » Sun Jan 10, 2021 8:44 am
I've done this without any problem by heating only the tube but I do want to say that it's only one solution among others but really, I think you make a big problem out of a small job.
Don't use a Bazooka to kill a fly. :doh:
Michel
