Expansion tank broken
#1 Expansion tank broken
Today I decided to check my coolant level and to my astonishment I discovered signs of leaks on top of the tank. Let the engine reach working temp and the tank was like a spring splattering out coolant as the pressure increased. I am not sure what crap tank was put on there and hope the new one ordered from SNGB will fare better. In the mean time I temporarily sealed up both pin holes with the trusty JB Weld and all seems well.
#2 Re: Expansion tank broken
You should get one of these:
https://cambridgemotorsport.com/61-jaguar
Not only look superb by matching the curvature of the bonnet and cam covers but will last forever! Why Jaguar spoiled the engine bay with the hideous oblong header tank I will never understand. Return the stock one to SNGB and buy the CMS one.
#3 Re: Expansion tank broken
That tank which Heuer knows I purchased AND
Without the Bung hole because I use an adjustable Hayden fan switch
Is a work of art!
ALL of the original style ones All of them are terrible
Good luck
Is a work of art!
Good luck
#4 Re: Expansion tank broken
#5 Re: Expansion tank broken
Thanks guys, I did consider Aluminium tanks most around the £500 mark which look very nice and of excellent quality but obviously require some investment. I decided to stick with the steel one for the now as it is more affordable and looks closer to the original but certainly not ruling out upgrading in the future.
#6 Re: Expansion tank broken
The last steel one I bought lasted about 9 months......
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
#7 Re: Expansion tank broken
So I’m feeling confused.
When there are postings about cars being sold, there seems to bit a lot of raised eyebrows over detailed parts not being identical (copies) to original, something that I would refer to as “horn push syndrome”. Doesn’t the replacement of a header tank with a shiny chrome version fit into this category ?
Notwithstanding the fact that DWW can do what he likes with his car
Darryl
#8 Re: Expansion tank broken
Trevor.
#9 Re: Expansion tank broken
Yes funny things forums...lots of different opinions
....its only original once when it left the factory...Steve
#10 Re: Expansion tank broken
It all depends on how the car is being advertised.
If it’s being sold as ‘restored to original spec’, ‘concourse restoration’ or ‘mint original’ etc etc then you can expect some raising of the eyebrows if elements have been changed/upgraded/poor replacement parts used.
Otherwise, it’s down to personal choice/taste.
#11 Re: Expansion tank broken
As far as my own car is concerned, it already had quite a few upgrades (five speed, front brakes, starter, alternator, cooling etc', but kept all the original parts) so it isn't concourse nor is it as it left the factory. My only consideration is that I am not quite ready to spend that much on an expansion tank at this point in time. Incidentally I received mine today from SNGB and it looks a better quality tank than the one I had on (about four years), so we are on to a 'good' start there.
#12 Re: Expansion tank broken
Hi Danny, the first mild steel header tank I bought for my 3.8 lasted 28 yrs,present mild steel tank 3yrs so far so good.Those polished aluminium tanks do look nice though.
Regards Gerry 62 Ots Ontario Canada.
#13 Re: Expansion tank broken
#14 Re: Expansion tank broken
This happened to me:
Is an 1.5 year old steel expansion tank from sngb.
I was hoping someone has some experiens with the brass expension tank.
Might be a better option.
I never considered a aluminium tank, but now I'm having doubts.
Marcel
OTS serie I '66
OTS serie I '66
#15 Re: Expansion tank broken
Ok, after much consideration and as per David's and Angus's recommendation I went ahead and ordered the curved polished aluminum header tank, last one they had in stock, from Cambridge Motorsport, should be with me in a day or two. Thanks for the recommendation.
#16 Re: Expansion tank broken
Blingtastic!
Did you specify a particular pressure cap? If not, just check what they supply as from memory I think the one that came with mine was too high.
#17 Re: Expansion tank broken
Thanks for the heads up, I called to enquire and they don’t supply the cap any longer for that very reason and recommend using the original.
#18 Re: Expansion tank broken
The jewellery piece arrived today, looks magnificent can't wait to install it
#19 Re: Expansion tank broken
You will love it.....Welcome to the dark side.!
No leaks and quality well beyond the original or repro.
gtjoey1314
gtjoey1314
#20 Re: Expansion tank broken
It wasn't easy
but in the name of peace of mind, progress and the appreciation of beauty......
