Best type of exterior mirrors
#41 Re: Best type of exterior mirrors
Post by rswaffie » Mon Oct 17, 2022 7:58 pm
I’ve had the Fosseway mirrors for a couple of years and apart from a little bit of grinding work on one small section of the mounting brackets to get a perfect fit, they have been solid.
caveman
#42 Re: Best type of exterior mirrors
Post by caveman » Wed Oct 19, 2022 12:16 pm
Similar mounting arms on mine but round mirror, all courtesy of Moggie Minor shop. Can’t fault them. :dance:
1965 S1 4.2 FHC (early)
:wavegreatbritain:
#43 Re: Best type of exterior mirrors
Post by DWW » Wed Oct 19, 2022 1:14 pm
As long as you install them under the felt they will be fine.
caveman
#44 Re: Best type of exterior mirrors
Post by caveman » Fri Oct 21, 2022 11:40 am
:yeahthat:
I also use bicycle inner tube rubber as part of the clamp system and haven’t had movement in 2 yrs.
:wavegreatbritain:
#45 Re: Best type of exterior mirrors
Post by Heuer » Fri Oct 21, 2022 1:09 pm
They fit and hold perfectly on a FHC window frame as it is flat. On the curved OTS frame you need to grind a profile into the base and use inner tube rubber to keep them in place.
pafagt
Guatemala
#46 Re: Best type of exterior mirrors
Post by pafagt » Wed Jan 25, 2023 3:17 pm
Hello.! My car has this type of mirror mounted in the bonnet. The original owner says it is how it came from new. With the car papers there is a document describing a Sebring mirror (it’s in German). I haven’t seen many cars with this kind of mirror. Could it be original to the car or perhaps dealer installed? Not sure I like it that much but if it’s really original to the car I would probably restore it and leave it. Thanks for your comments .!
Pablo
Pablo
1956 Mercedes 190 SL
1973 Porsche 911 T targa
1969 Porsche 912
1970 Alfa 1300 GT junior Scalino (sold)
1966 Jaguar e type FHC (unfortunately sold)
1967 Jaguar e type OTS 1.25 series
1976 Toyota FJ40 (I learned to drive with this one)
#47 Re: Best type of exterior mirrors
Post by Heuer » Wed Jan 25, 2023 3:54 pm
Aftermarket and not Factory.
pafagt
Guatemala
#48 Re: Best type of exterior mirrors
Post by pafagt » Wed Jan 25, 2023 4:03 pm
Thanks David, that’s what I thought. What would be period correct for a late 67.? Talbots Berlin ?
Pablo
1969 Porsche 912
#49 Re: Best type of exterior mirrors
Post by Heuer » Wed Jan 25, 2023 4:25 pm
Yes, something like a Talbot although my recommendation would be to go with one of the clip on mirrors as mentioned above.
Allrand
#50 Re: Best type of exterior mirrors
Post by Allrand » Thu Jan 26, 2023 9:48 am
I've also thought of mounting a mirror like that on the bonnet/wing joint to avoid drilling holes, but I think it's too far in from the edge to be able to see properly past the A pillar etc.
Randall Botha
vipergts
#51 Re: Best type of exterior mirrors
Post by vipergts » Thu Jan 26, 2023 8:14 pm
These look cool
Do you have a link? I can’t seem to find them.
S1 4.2 Roadster in Resale Red
caveman
#52 Re: Best type of exterior mirrors
Post by caveman » Sat Jan 28, 2023 10:51 am
:wavegreatbritain:
mtnjag
#53 Re: Best type of exterior mirrors
Post by mtnjag » Sat Jan 28, 2023 2:26 pm
I have the one in post 41. Very nice mirror. Stays where you adjust it, fairly quiet(wind), good view. Attractive shape.
I had the rectangular one in the post 52 link. Very high wind noise. The shape and flat arm i imagine.
Watch out for those flat arms. Doesn’t look as nice either of course.
Layne
Car #876005, 62 OTS
vipergts
#54 Re: Best type of exterior mirrors
Post by vipergts » Sat Jan 28, 2023 8:16 pm
Here you go, mine are top link, I'm very pleased with them, no issues and a lot of adjustment:
https://www.morrisminorspares.com/misce ... ex-p831190
https://www.morrisminorspares.com/misce ... ix-p831195
https://www.morrisminorspares.com/misce ... ix-p831224
Superb. Many thanks
ysmalkie
Poland
#55 Re: Best type of exterior mirrors
Post by ysmalkie » Tue Sep 17, 2024 12:24 pm
Does anyone know where to find this mirror?
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
rfs1957
#56 Re: Best type of exterior mirrors
Post by rfs1957 » Tue Sep 24, 2024 2:17 pm
Anyone wanting a Fosseway mirror should jump, quick, Simon has some stock again.
