Post
by mgcjag » Sat Feb 04, 2023 1:06 pm
Thanks for the replies.......dosnt quite answer my speeker ohm rating problem as in the diagram above it mentions 1 speaker 5ohm.....2 speaker in shunt 2.5ohm......anyone have info of the Hamburg speaker rating.....do i actually need to get it right......could i use either a 4ohm or an 8ohm in the one speaker position.....would useing the wrong one blow the o/p......thanks......Steve
PS..found this info in one of the links above...just need same info for 60,s units ......"These mono output radios are designed to run either one or two speakers. Speakers should be 8 ohm through the mid 1970's. Using 4 ohm speakers will damage these 8 ohm radios over time"
