Master Brake/ Clutch Cylinder Aluminium Tags
swindler
#21 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by swindler » Mon Aug 15, 2022 9:19 am
I'll take a set of three too, please
3.8 OTS 1964
Original RHD. Close ratio moss box
splosh
#22 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by splosh » Thu Aug 18, 2022 11:40 pm
Hi Keith,
Excellent Job. Could you put me down for three also please?
August 1961 roadster.
Clive
(Hampshire)
Clive
August 1961 Flat floor ots
caveman
#23 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by caveman » Fri Aug 19, 2022 2:48 pm
Hi Keith,
I would interested in two for the brake cylinders for my May 1965 S1 FHC :thankyouyellow:
1965 S1 4.2 FHC (early)
:wavegreatbritain:
ysmalkie
Poland
#24 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by ysmalkie » Fri Sep 09, 2022 6:32 pm
I think at a certain point the tags became plastic - it must have been between before September & December '62
886953 FHC 09 '62
887530 FHC 12 '62
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Philk
#25 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Philk » Wed Sep 14, 2022 8:43 am
Hi - Any update on these?
1964 S1 3.8 OTS
Maikel
#26 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Maikel » Mon Oct 17, 2022 5:46 am
Good day,
I know found an unmolested 3.8 pedal box with all 3 labels on the master cylinder. Just to help with date and number of tags.
The date on the plastic tags says 12/62.
If nobody has an earlier date, we could as per today agree that the aluminum tags were used until 11/62.
Nice being in UK again for a couple of days.
Maikel
#27 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by DWW » Mon Oct 17, 2022 12:44 pm
Sent the guy a pm, didn’t even bother to reply.
Philk
#28 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Philk » Fri Oct 28, 2022 12:10 pm
Good day,
Maikel
Hi Maikel
That's a great find (and definitely worthy of an update within the 3.8 Factory Fit section).
1964 S1 3.8 OTS
#29 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Heuer » Fri Oct 28, 2022 1:08 pm
All ready done!
Philk
#30 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Philk » Sat Nov 05, 2022 10:00 am
So... for those of us with post Dec '62 3.8 cars, the hunt is now on for someone who could supply replica plastic tags as opposed to the Aluminium tags. Has anyone had any success with this in the past. If not, could someone produce a template from a tag they already possess?
1964 S1 3.8 OTS
#31 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Heuer » Sat Nov 05, 2022 11:49 am
A 3D printer would make relatively quick work of the plastic tags if someone has a sample.
typea59
#32 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by typea59 » Wed Nov 23, 2022 7:44 am
Interesting for 3 if still possible 🤞
Loïc
11/61 OTS 875987
Citroën 2cvA 1953
#33 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by DWW » Wed May 24, 2023 10:36 am
Surprised this morning when these arrived in the post, thank you Keith (New Zealand) most grateful.
Geoff Allam
#34 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Geoff Allam » Wed May 24, 2023 2:50 pm
Another vote for a supply of plastic tags. Much larger market too. BTW those aluminium ones look great.
Geoff Allam
#35 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by DWW » Wed May 24, 2023 3:58 pm
Thanks, just need to wait for the next opportunity the planum comes off in order to install them on the corresponding masters.
Philk
#36 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Philk » Fri May 26, 2023 4:08 pm
:yeahthat:
1964 S1 3.8 OTS
ysmalkie
Poland
#37 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by ysmalkie » Sun May 28, 2023 7:48 pm
I have one sample - were they all the same?
I could arrange for printing them.
Tadek
Tadek
Jaguar XK120 OTS
jaspercat10
#38 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by jaspercat10 » Fri Aug 11, 2023 4:54 pm
Been trying to get a response from him on this? Is anyone else receiving anything ?
#39 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by DWW » Fri Aug 11, 2023 5:36 pm
Yes, quite a while ago I received the three I asked for, they are all have different inscriptions corresponding to the masters...
cactusman
#40 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by cactusman » Sun Aug 27, 2023 9:42 am
May 62 car...think you are way past 50 already but if not three please? Julian
