Bearing Choice
Dad
#1 Bearing Choice
Post by Dad » Mon Aug 28, 2023 3:19 pm
I believe it's time to change one of my front bearings (it weirdly overheated and now has play). Before I start filling a shopping cart with stuff from Moss or wherever, are all bearings created equal? Should I automatically assume I should just get one from Moss, or is there more to it?
Any advice on choice of bearing would be greatly appreciated.
Thanks.
1966 s1 FHC 4.2
mxke
#2 Re: Bearing Choice
Post by mxke » Mon Aug 28, 2023 3:23 pm
Be very wary of the ones produced in China.
#3 Re: Bearing Choice
Post by mgcjag » Mon Aug 28, 2023 4:26 pm
Timken would be my choice....Steve
Dad
#4 Re: Bearing Choice
Post by Dad » Mon Aug 28, 2023 8:15 pm
mgcjag wrote: ↑
Thanks Steve. I don't suppose you have a catalogue reference or tech specs?
1966 s1 FHC 4.2
#5 Re: Bearing Choice
Post by mgcjag » Mon Aug 28, 2023 8:20 pm
Pull your bearings and look at the part numbers...or SNGB website...this outer bearing you can see in the photo https://www.sngbarratt.com/English/#/UK ... c92fab1b5a
mxke
#6 Re: Bearing Choice
Post by mxke » Mon Aug 28, 2023 10:48 pm
Just sent you a PM.
Mike
mxke
#7 Re: Bearing Choice
Post by mxke » Mon Aug 28, 2023 11:04 pm
Wheel bearings can be purchased in "sets". I believe the E Types are a set 2 and a set 6 for the inner/outer, but check the numbers.
Mike
Dad
#8 Re: Bearing Choice
Post by Dad » Tue Aug 29, 2023 12:29 am
Many thanks
mxke wrote: ↑
Mike
1966 s1 FHC 4.2
jannickz
#9 Re: Bearing Choice
Post by jannickz » Thu Nov 30, 2023 3:04 am
For your front wheel bearing, I would recommend getting a bearing from a reputable brand and made from high-quality materials. You should also make sure that the bearing has the correct tolerance for your application.
I would not recommend getting a bearing from Moss or another supplier unless you are sure that they are selling a high-quality bearing from a reputable brand. There are a number of counterfeit bearings on the market, and these bearings can be dangerous. They can fail prematurely and cause an accident.
