Difficulty refitting carburettors
PhilBell
#1 Difficulty refitting carburettors
Post by PhilBell » Mon Mar 18, 2024 2:24 pm
I'm having difficulty refitting carburettor (standard SU HD8) number 1 after I removed all three of them a few months ago. Apart from how awkward access was to some of the linkages and the nuts securing the carbs, I don't recall any particular difficulties when I removed them. Now I can't get carb number 1 to engage on its mounting bolts because the bottom of the float chamber fouls the steering column seal housing. What am I missing here?
1962 FHC 885626
#2 Re: Difficulty refitting carburettors
Post by Heuer » Mon Mar 18, 2024 2:38 pm
Loosen engine mounts and jack up the engine slightly to clear the housing.
PhilBell
#3 Re: Difficulty refitting carburettors
Post by PhilBell » Tue Mar 19, 2024 8:25 pm
Thanks David, I was thinking similar, but still baffled how I managed to extract the carb in the first place. Then again, that was many months ago and memories fade.
1962 FHC 885626
phoenix
#4 Re: Difficulty refitting carburettors
Post by phoenix » Wed Mar 27, 2024 11:57 am
Yes they are a bit of a tease to fit especially the nuts at the rear underneath . Plenty of scratched hands usually. I do not think there is an easy way.
S1 4.2 RHD Bryan
PhilBell
#5 Re: Difficulty refitting carburettors
Post by PhilBell » Sat Mar 30, 2024 9:59 am
'A bit of a tease to fit' - love that, the words forming in my head as I repeatedly dropped either the lower nuts, spring washers or both were somewhat less polite.
1962 FHC 885626
#6 Re: Difficulty refitting carburettors
Post by bitsobrits » Sat Mar 30, 2024 12:24 pm
Try it with the distributor removed. I found it much easier to reach in from the front.
