So I had to source all alu parts except gauge panel. Center console is the original from the car, both alu pieces are from another car
So the questions now are:
1-Does the shifter alu sit on top of or below the center console opening?
2-Is it attached with screws or rivets or?
3-The red bead, is it also screwed/riveted or just glued in?
4-The large alu piece, I have no idea how that's attached. There are no markings on the wood on the underside from either screws or glue? It looks unused, but it isn't, a few scratches on top
5-When all this is assembled, what do I install first in the car, this center console or the radio console?
(Don't worry about screws in shifter surround, just thought it was easier to get the leather correct, will be replaced by correct rivets)
