Brake Reservoirs.
#1 Brake Reservoirs.
I have noticed some Series 1 eTypes have two brake reservoirs and a clutch reservoir some on the drivers side (RHD) some on the passenger side, some have one brake reservoir and one clutch reservoir. Also the brake servo seems to be interchangeble between the drivers (RHD) side and the passenger's side of the engine bay.?. Can anyone explain what the correct combination should be for a RHD UK 1965 Series 1 4.2 coupe???. :D
Mines a late 64 RHD... so I imagine its the same. There are 2 reservoirs on the drivers side. Outside one is brake fluid, inside one is clutch. This makes the metal pipe fitting a little easier. There is a third reservoir on the passenger side which drops fluid into the master cylinder. There are pictures on my blog but I can pull some out if you want.
1964 FHC 4.2
Many thanks for the reply, your photos have clarified things. You have a superb looking car, I can only dream that mine might look something like yours someday!!. :D
Many thanks for your kind words... I am sure you too will have a nice car - it just takes time and patience if your are doing it yourself - or a lot of money if someone else does it for you
1964 FHC 4.2
To be strictly correct the outside one should be the clutch fluid and the inner one the brakes:
Really? Oh well never mind too late for me now :)
1964 FHC 4.2
Don't you find it disconcerting that when you press the brake pedal the clutch disengages?
I think brakes are over rated - I try never to use them and merely wave my arms about and shout "coming through"...
1964 FHC 4.2
I'm after some assistance establishing whether my fluid reservoirs are of the correct type for year. My RHD 3.8 OTS was built October 62 and has the 3 square reservoirs on the bulkhead. They don't look like they've ever been changed. On reading Haddock's guide it states that there were 3 different bottle types used, the later cars having the square bottles. However SNG Barratts are only giving the 3 round bottles as the option for my car.
Can anyone confirm if these are correct for my car ?
Many thanks in anticipation.
Neil
1962 S1 OTS
1967 S1 FHC
1962 S1 OTS
1967 S1 FHC
Square bottles from chassis #877557, #850556, #886283 and #860678
Thanks David.
In that case they're correct. I'm hoping to salvage the existing bottles as I have read about all the issues with the repros. The lids are not salvageable though so I need to replace them. I have seen a number of different options on the lids / senders. Some have a wide aluminium tube beneath & some a thin plastic tube. Mine were originally a needle & float. Which are the ones to go for ?
Neil
1962 S1 OTS
1967 S1 FHC
1962 S1 OTS
1967 S1 FHC
My OTS is June 64 so a very late 3.8. It has the same as yours.neil4444 wrote:
Extract from JCNA judging guide:
Thanks David but I'm confused as to the correct tube (ali vs plastic) see below links:
http://www.ebay.co.uk/itm/221446420787? ... 1423.l2649
http://www.ebay.co.uk/itm/271509174880? ... 1423.l2649
Neil
1962 S1 OTS
1967 S1 FHC
1962 S1 OTS
1967 S1 FHC
Second one is correct and genuine Jaguar it seems - snap it up (because the repro's will snap)!
