Does anyone have a knob like this?
Lambo911
#1 Does anyone have a knob like this?
Post by Lambo911 » Wed Sep 03, 2014 1:55 pm
I have a strange knob! The one next to the ignition.
It isn't in the handbook and I'm not sure what it does, can anyone help please?
[img][img]http://i36.photobucket.com/albums/e21/r ... 0136d8.jpg[/img][/img]
____________
1972 S3 2+2 - Black with Red leather, 4 Speed and Wires
1966 S Type 3.8 MOD - ex South Africa
1994 XJS V12 coupe - 59,000 miles
Post by malcolm » Wed Sep 03, 2014 2:41 pm
Could be for girls to hang their handbags on? :D
Post by Heuer » Wed Sep 03, 2014 3:31 pm
Curry hook?
andrewk
Post by andrewk » Wed Sep 03, 2014 4:25 pm
Does your horn work by pushing down on the steering wheel centre?
When I first got my car I had a separate "horn button" on the dash as the contacts on the steering column were broken.
From what I understand, the contacts on the column are a weak spot and when they would wear, the horn would sound when turning the wheel.
73, OTS
Lambo911
Post by Lambo911 » Wed Sep 03, 2014 7:19 pm
Horn push still works on the wheel.
I'll do some investigation and try and chase the wires.
I'm guessing it's an after market knob then as opposed to a factory item.
____________
Post by PeterCrespin » Wed Sep 03, 2014 9:28 pm
Certainly aftermarket but what is the action? I bet it's a pull-push that stays in either position, not a spring return push knob.
If so, look for reversing lights or some kind of fog light or even manual fan override. On open cars the right hand rocker switch is often used for this kind of thing but since yours is already spoken for by the fitted rear window heater the PO would have had to do something else.
Is this when you gleefully discover you have an overdrive manual box? :-)
Lambo911
Post by Lambo911 » Wed Sep 03, 2014 10:23 pm
It's a weird dual action, clicks if you pull it out but has a sprung action if you push it.
I'm quite excited now to find out what it does!
____________
ralphr1780
Post by ralphr1780 » Thu Sep 04, 2014 7:54 am
Probably the seat "Eject". :lol:
Ralph
'69 OTS + '62 OTS - Belgium
Mountain King
Post by Mountain King » Fri Sep 05, 2014 12:37 pm
Air Strangler?
but i think that is only on later zentih carbs.
1973 Series 3 OTC
Alty Ian
Post by Alty Ian » Fri Sep 05, 2014 12:48 pm
Check under the car for neon lights :lol:
64 S1 4.2 OTS 1E10012 73 S3 2+2 manual 2013 V6 F type OTS
Lambo911
Post by Lambo911 » Fri Sep 05, 2014 3:30 pm
The car has spent 16 years in Johannesburg South Africa so it could be some kind of anti-hijack control!
Would be cool to have side flame throwers ! :twisted:
____________
JaggyWag
#12
Post by JaggyWag » Fri Oct 10, 2014 8:18 pm
I think it might be a switch that prevents the operator from posting on this forum? Anybody else still wondering? :lol:
Lambo911
Post by Lambo911 » Sat Oct 11, 2014 7:52 am
Ha ha!
I haven't had any luck tracking down what it does yet. I can't easily get to the wiring. I will try again!
____________
GravyGraham
Post by GravyGraham » Sun Feb 08, 2015 10:36 pm
Well, any luck? The suspense is killing us.
'72 Series 3 2+2, pale primrose/black
(plus miscellaneous Land Rovers!)
