The OD gearbox in my car has a 1:1 speedo output ratio, our cars have a 1:1.25 ratio at the speedo, this meant I needed a hybrid angle drive. When I fitted it, my speedo was rock solid & accurate, it had just been reconditioned too. However, after a hundred miles or so it packed in, on removing the angle drive today this is what I found. Any ideas what could cause this? the speedo cable rotates freely and the speedo moves fine when I turn the cable manually. Is it possible that this wire has been wound the wrong way and has started to untwist?
Ian
