Hole vacum igintion
christophe37
#1 Hole vacum igintion
Post by christophe37 » Sat Jun 06, 2015 5:22 pm
Please my car was modified for the precedent owner.
Wherer go the hole (vacum) ignition (where is connected ?)
One side vaculm other side ??????
(sorry for my very bad english)
Christophe
Post by PeterCrespin » Sat Jun 06, 2015 6:18 pm
N'as tu pas un manuel de service? Tu dois en acheter un.
If the previous owner modified the ignition you need to check if it is still vacuum retard (working from the thermostatic valve) or a vacuum advance module from an XJS (connected to ported vacuum). If it looks like the workshop manual it's retard. You also need to check if it is or was an emissions car and the connections have been modified.
Woolfi
Post by Woolfi » Mon Jun 08, 2015 12:13 am
If it is retard, you don't need it. You can disconnect it.
Regards Wolfgang Gatza
