Please my car was modified for the precedent owner.
Wherer go the hole (vacum) ignition (where is connected ?)
One side vaculm other side ??????
(sorry for my very bad english)
Christophe
Hole vacum igintion
christophe37
Topic author - Posts: 20
N'as tu pas un manuel de service? Tu dois en acheter un.
If the previous owner modified the ignition you need to check if it is still vacuum retard (working from the thermostatic valve) or a vacuum advance module from an XJS (connected to ported vacuum). If it looks like the workshop manual it's retard. You also need to check if it is or was an emissions car and the connections have been modified.
If it is retard, you don't need it. You can disconnect it.
Regards Wolfgang Gatza
