Ball joint gaiters
Freddie116
#1 Ball joint gaiters
Post by Freddie116 » Tue Jul 12, 2016 7:58 pm
Hello, new to the forum. Have just had an mot fail due to upper ball joint gaiter failure. Had this two years ago with the lowers and replaced them with new clear plastic ones. I now can see that these have started to deteriorate already aft just 2 years. They will survive this mot but I don't want to fit rubbish ones again to the top ball joint if they will deteriorate again. Anyone suggest where I can get high quality ones? Can't recall where I got last ones. Could have been sngb?
#2 Re: Ball joint gaiters
Post by Gfhug » Wed Jul 13, 2016 7:07 am
This is the complete upper balljoint from SNGB
http://www.sngbarratt.com/ProductDetail ... df203e295a
This is the gaitor:
http://www.sngbarratt.com/PartSearchRes ... tno=C43216
Give them a call and explain what you need and you'll find them very helpful
Freddie116
#3 Re: Ball joint gaiters
Post by Freddie116 » Wed Jul 13, 2016 7:16 am
Thanks. I saw these. I'm assuming you get what you pay for judging by the price. Maybe I bought the £1 ones last time, in which case I advise no one else to do so!
neil4444
#4 Re: Ball joint gaiters
Post by neil4444 » Wed Jul 13, 2016 7:29 am
Hi Freddie,
Welcome to the forum. Suggest you delete your duplicate post on Welcome section so you don't start getting answers in 2 places. You only need to post things in one place as people will always pick it up.
Cheers,
Neil
1962 S1 OTS
1967 S1 FHC
Freddie116
#5 Re: Ball joint gaiters
Post by Freddie116 » Wed Jul 13, 2016 8:01 am
Sorry, yes, I realised I had put it in the wrong place then copied it over. Will delete
#6 Re: Ball joint gaiters
Post by mgcjag » Wed Jul 13, 2016 8:01 am
I recently replaced my ball joint gaitere....with the clear/opaque type.....note that tne large end is too big to fit on the wishbone end a circular adaptor ring is needed.....the SNG ones were to stiff to fit...suppose i could have put them in hot water....but i got some softer Jaguar ones from CMC.....they now have a parts department part no is C22970..here is a link to the SNG ones http://www.sngbarratt.com/PartSearchRes ... tno=C22970
Freddie.......take tne opertunity to check that the ball joint actually moves nice and smoothly.....changed my gaiters recently and found grindy movement in tne ball joint.....tf you change them use tbe procedure in tbe manual to get tbe shimming correct
Freddie116
#7 Re: Ball joint gaiters
Post by Freddie116 » Wed Jul 13, 2016 5:39 pm
Thanks, just ordered the jag made gaiters from sng (they do a cheap repro version but I suspect that's what I got last time and they have cracked a little already). I didn't know that I also needed something else to fit them - something for the wishbone end? I will see if I can add that to the order. What are they called exactly?
Freddie116
#8 Re: Ball joint gaiters
Post by Freddie116 » Wed Jul 13, 2016 5:41 pm
Sorry - just noticed that the link you posted was for the adaptors - thanks!
