Rear light under riders
Bernie2015
#1 Rear light under riders
Post by Bernie2015 » Sat Aug 20, 2016 9:37 am
Hi all, I have bought chrome under riders for the rear lights on my series 2 but cant work out how they fit. There is a place for a bolt to be screwed into the under rider itself but cant work out how it fits to the lamp unit - any help much appreciated.
Bernie 1966 S1 OTS
#2 Re: Rear light under riders
Post by mgcjag » Sat Aug 20, 2016 9:44 am
Whats an under rider?
iani
#3 Re: Rear light under riders
Post by iani » Sat Aug 20, 2016 10:02 am
I expect Bernie means the finisher, BD35741, there is a cutout behind the light, the bolt passes through this and screws into the finisher.
Ian
Jaguar - S2 FHC, X150 5.0 XKR
1968 Triumph GT6 Mk1
Bernie2015
#4 Re: Rear light under riders
Post by Bernie2015 » Sat Aug 20, 2016 12:18 pm
Thanks Ian yes its BD35741, I can't see a cutout behind the light could you point me in the direction of a diagram or photo somewhere
Bernie 1966 S1 OTS
#5 Re: Rear light under riders
Post by mgcjag » Sat Aug 20, 2016 12:27 pm
Have a look here Bernie took me 1min with a google search http://www.jagexp.com/phorum/read.php?4,11987
Bernie2015
#6 Re: Rear light under riders
Post by Bernie2015 » Sat Aug 20, 2016 1:25 pm
Thanks but it doesn't show what the long securing bolt attaches to on the body of the car before screwing into the finisher
Bernie 1966 S1 OTS
iani
#7 Re: Rear light under riders
Post by iani » Sat Aug 20, 2016 1:51 pm
Having searched a few parts catalogues, this bracket doesn't seem to be listed anywhere. On my car, it is a U shaped bracket, welded onto the rear valance, it sits behind the light mounting panel, the U section is around 1" long and item 39 http://www.sngbarratt.com/CatalogueProd ... 887&a=7617 is supposed to sit on the inboard side of the bracket, you then do the bolt up to hold the part in place.
#8 Re: Rear light under riders
Post by mgcjag » Sat Aug 20, 2016 2:29 pm
Hi Bernie....did you look through all tne link i gave....the 2nd photo shows the head of the long bolt fitted in tne bracket that Ian explains above
Bernie2015
#9 Re: Rear light under riders
Post by Bernie2015 » Sun Aug 21, 2016 9:15 am
I think I need the 'u' shaped bracket mentioned but I can't find it listed anywhere. All I can see in the second photo is the head of the self tapping screw Im afraid.
Bernie 1966 S1 OTS
Bernie2015
#10 Re: Rear light under riders
Post by Bernie2015 » Sun Aug 21, 2016 9:24 am
Had to join the Jaguar Experience forum so can see the photo now thanks. It seems I need that 'U' shaped bracket to fix bolt through which I cant find.
Bernie 1966 S1 OTS
#11 Re: Rear light under riders
Post by mgcjag » Sun Aug 21, 2016 9:31 am
Hi Bernie...the brackets are welded on...i suppose u could probably rivet or screw them on....try Hutsons they have lots of body panels Try to find a photo on a bare shell from tne rear ps the chrome finisher is also known as a Clam shell
Bernie2015
#12 Re: Rear light under riders
Post by Bernie2015 » Sun Aug 21, 2016 12:41 pm
Many thanks Steve
Bernie 1966 S1 OTS
mark10337
Switzerland
#13 Re: Rear light under riders
Post by mark10337 » Fri Aug 26, 2016 8:34 pm
I have been having great difficulty getting the reinforcing washer - Part 39 on the SNG diagram
Without it I can't mount the finisher either. Has anyone got a source for this, or dimensions?
-Mark
iani
#14 Re: Rear light under riders
Post by iani » Sun Aug 28, 2016 1:17 pm
Mark,
If you have the U shaped bracket, you only need a washer that will sit behind that and allow the bolt to pull the finisher in tight.
If you don't have the U shaped bracket, you really need a photo from someone who has a car with the rear end partially dismantled, I'd suggest approaching Angus, if he doesn't have one now, he no doubt will have soon.
Neither the bracket nor the washer would be difficult to fabricate, you just need some pics and dimensions.
Ian
Bernie2015
#15 Re: Rear light under riders
Post by Bernie2015 » Tue Sep 13, 2016 12:39 pm
I have the bolts and washer now but access is proving very difficult to tighten up . Any tips?
Bernie 1966 S1 OTS
mark10337
Switzerland
#16 Re: Rear light under riders
Post by mark10337 » Tue Sep 13, 2016 3:18 pm
No tips except perseverance I'm afraid. Where did you manage to source the washer from or did you get one made? Could you let me have the dimensions before you finally bolt it on?
-Mark
Bernie2015
#17 Re: Rear light under riders
Post by Bernie2015 » Tue Sep 13, 2016 5:33 pm
Its down at the garage but next time Im there will measure it
Bernie 1966 S1 OTS
Bernie2015
#18 Re: Rear light under riders
Post by Bernie2015 » Tue Sep 20, 2016 12:26 pm
Hi Mark,
sorry I havent been down to the garage recently but just pulled a washer off the shelf that fitted - no specific size hope that helps.
Bernie 1966 S1 OTS
