I need to replace the feed and suction pipes connected to the oil pump as part of my engine rebuild. I have gone through all the usual suppliers SNG, Robey, SC, XKS but with no luck. Anyone got any suggestions for other suppliers?
3.8 oil pump pipe suppliers?
#1 3.8 oil pump pipe suppliers?
KoosKorver
#2 Re: 3.8 oil pump pipe suppliers?
Did you ever find a solution to the pump pipe suppliers? I'm desperately searching for an original delivery pipe from pump to block, suction pipe from sump to pump and plate sealing bottom of suction pipe. Do you have any suggestion?
#3 Re: 3.8 oil pump pipe suppliers?
You might find Rob Beere Racing http://rob-beere-racing.co.uk/ could help or point you in the right direction.
#4 Re: 3.8 oil pump pipe suppliers?
From memory, when The Splined Hub rebuilt my engine, they put in a later oil pump with the associated hoses.
#5 Re: 3.8 oil pump pipe suppliers?
Post an ad in out wanted section if your after original parts.....Steve
#6 Re: 3.8 oil pump pipe suppliers?
Jaguar upped the size of the pipe with the 4.2 item which matched the size of the new oil pump intake . Any 3.8 pump to block pipe is the same so check any saloon engine for spares. The sump pick up pipe is E-type only. The 3.8 pumps became unavailable many years ago - we used to modify 3.8 pick up pipes with a sleeve so they would fit the new (4.2) pumps .Why bother with doing this when you can use a 4.2 set up (pump and both pipes) it fits right on ?
Barrie
C21760 and C22595 available from Barratt
Barrie
#7 Re: 3.8 oil pump pipe suppliers?
I think that’s what Splined Hub did with my engine - put the later 4.2 pump and pipes in.
