Luggage strips in S1 4.2 Coupe
Michaelg
#1 Luggage strips in S1 4.2 Coupe
Post by Michaelg » Sat Jun 03, 2017 5:12 pm
Does any one know whether the luggage strips in an S1 1966 4.2 Coupe should be be pointed at the ends, or straight?
I've seen both. Suffolk and Turley certainly seem to produce pointed ends.
Michael g. 1966 S1 FHC. 1969 S2 OTS
#2 Re: Luggage strips in S1 4.2 Coupe
Post by Heuer » Sat Jun 03, 2017 5:29 pm
Pointed:
Photos of original cars in our 4.2 Factory Fit thread: viewtopic.php?f=4&t=2007
cactusman
#3 Re: Luggage strips in S1 4.2 Coupe
Post by cactusman » Sat Jun 03, 2017 6:13 pm
Yep..all the ones I have seen are pointed.....and rare as rocking horse manure...
Michaelg
#4 Re: Luggage strips in S1 4.2 Coupe
Post by Michaelg » Sat Jun 03, 2017 9:15 pm
Many thanks for the replies. I thought as much. Now to convince my trimmer who should know better...
#5 Re: Luggage strips in S1 4.2 Coupe
Post by abowie » Sat Jun 03, 2017 10:01 pm
Not sure that's correct.
I have pointed ones in my 3.8 coupe, but my June 1967 4.2 coupe has squared ones.
When was the changeover?
#6 Re: Luggage strips in S1 4.2 Coupe
Post by Heuer » Sat Jun 03, 2017 11:02 pm
All I can see is a big white box with some random parts in it :shrug: The FHC in the Factory Fit thread is a Jan 1966 car so at least pointy until then. A case of checking XKEdata photos and see if you can find a changeover point. But as the OP has '66 car I would say pointy is correct.
Michaelg
#7 Re: Luggage strips in S1 4.2 Coupe
Post by Michaelg » Sun Jun 04, 2017 5:08 am
Thanks Andrew and David. I'll do a bit more research before chiding the trimmers. It is a December 1966 car.
Michaelg
#8 Re: Luggage strips in S1 4.2 Coupe
Post by Michaelg » Sun Jun 04, 2017 5:24 am
From comparing the various photos on XKE Data (thank you David fror pointing me in that direction) it does seem that there was a change from pointy to square between May and July 1966. Problem solved I think. Thanks to you both.
#9 Re: Luggage strips in S1 4.2 Coupe
Post by abowie » Sun Jun 04, 2017 6:14 am
Heuer wrote:All I can see is a big white box with some random parts in it :shrug:
You can see the square ends on the foldy uppy thing.
And yes; a few bits of MGA I think..
Bertson
#10 Re: Luggage strips in S1 4.2 Coupe
Post by Bertson » Sun Jun 04, 2017 6:01 pm
Hello,
my S1 2+2 hast the squared ones and is from May 1966....
#11 Re: Luggage strips in S1 4.2 Coupe
Post by Heuer » Sun Jun 04, 2017 6:06 pm
Ahh, see it now Andrew. I was searching the box!
