Luggage strips in S1 4.2 Coupe
#1 Luggage strips in S1 4.2 Coupe
Does any one know whether the luggage strips in an S1 1966 4.2 Coupe should be be pointed at the ends, or straight?
I've seen both. Suffolk and Turley certainly seem to produce pointed ends.
Michael g. 1966 S1 FHC. 1969 S2 OTS
#2 Re: Luggage strips in S1 4.2 Coupe
#3 Re: Luggage strips in S1 4.2 Coupe
Yep..all the ones I have seen are pointed.....and rare as rocking horse manure...
#4 Re: Luggage strips in S1 4.2 Coupe
Many thanks for the replies. I thought as much. Now to convince my trimmer who should know better...
#5 Re: Luggage strips in S1 4.2 Coupe
Not sure that's correct.
I have pointed ones in my 3.8 coupe, but my June 1967 4.2 coupe has squared ones.
When was the changeover?
#6 Re: Luggage strips in S1 4.2 Coupe
All I can see is a big white box with some random parts in it
The FHC in the Factory Fit thread is a Jan 1966 car so at least pointy until then. A case of checking XKEdata photos and see if you can find a changeover point. But as the OP has '66 car I would say pointy is correct.
#7 Re: Luggage strips in S1 4.2 Coupe
Thanks Andrew and David. I'll do a bit more research before chiding the trimmers. It is a December 1966 car.
#8 Re: Luggage strips in S1 4.2 Coupe
From comparing the various photos on XKE Data (thank you David fror pointing me in that direction) it does seem that there was a change from pointy to square between May and July 1966. Problem solved I think. Thanks to you both.
#9 Re: Luggage strips in S1 4.2 Coupe
You can see the square ends on the foldy uppy thing.Heuer wrote:All I can see is a big white box with some random parts in it![]()
And yes; a few bits of MGA I think..
#10 Re: Luggage strips in S1 4.2 Coupe
Hello,
my S1 2+2 hast the squared ones and is from May 1966....
#11 Re: Luggage strips in S1 4.2 Coupe
Ahh, see it now Andrew. I was searching the box!abowie wrote:You can see the square ends on the foldy uppy thing.Heuer wrote:All I can see is a big white box with some random parts in it![]()
