Valve timing gauge
#1 Valve timing gauge
Looking for someone who could provide a photo of the valve timing gauge with a ruler in the frame.
Thanks for the help
Jim
Thanks for the help
Jim
#2 Re: Valve timing gauge
Hi Jim.... sorry dont recognise the term..valve timing guage....what us it......Steve
#3 Re: Valve timing gauge
Thanks Steve
It is a flat steel gauge that fits over the end of the camshaft on engine assembly that holds the camshaft in position while the #6 piston is at TDC.
#4 Re: Valve timing gauge
#6 Re: Valve timing gauge
They are readily available to buy for about £10 ($15) so no reason to make an imperfect one from guessing dimensions from a photo if that is your plan
#7 Re: Valve timing gauge
Great information. Where are they available from?
Jim
Jim
#8 Re: Valve timing gauge
Jim...google is your friend...just search Jag cam setting tool
Lost Horizon
#10 Re: Valve timing gauge
Try Browns Lane Jaguar. Canadian E-Type specialist and parts supplier. He likely has them in stock.
http://brownslane.com/
Keith
Keith
1967 S1.25 OTS, 1952 MG TD
#11 Re: Valve timing gauge
Thanks all. The photo was great. Have the drawing done.
Easy cut from 3/16 plate.
Jim
Jim
#12 Re: Valve timing gauge
Still wouldn't do that Jim. It may not look it, but the measurements are very sensitive. Little bit out, and engine won't be perfect. Just get one sent from UK if you can't source it.
