The 5 Speed is here……..
#461 Re: The 5 Speed is here……..
Ferrari used a quilted tunnel cover without console on some of their sports coupes....
#463 Re: The 5 Speed is here……..
The bubble gator is silicone as Heuer said before and larger that does not pull!
I cannot get out of the car!!!!
My xo pilots are back!
Going to bed soon Long two days ahead
Gtjoey1314
Gtjoey1314
#464 Re: The 5 Speed is here……..
#465 Re: The 5 Speed is here……..
I ordered a yard of factory style rug and binding
From Bartlett/Osji
So I can start my custom tunnel area.
Wish me luck the D. Type is on the block on Saturday
From Bartlett/Osji
#466 Re: The 5 Speed is here……..
Guys...please see my previous posts...Lets keep this post to the 5 speed. .....if you want to deviate then please start another thread.....if its on the D type them please post in the...My dream garage....or pub chat section. ....thanks.....Steve........Ok so you didnt listen so iv deleted the posts. ......
#467 Re: The 5 Speed is here……..
To wrap the 5 speed up
Shimmed the e brake out so it hugs the tunnel not your leg!
Rug on the way
Spacing the e brake handle it doesn’t get hot
Take a look
It makes a huge difference with the leg room!
Rug on the way
Take a look
#468 Re: The 5 Speed is here……..
And the console still fits?
#469 Re: The 5 Speed is here……..
It could BEFORE this tweek but I want to go in this direction I never liked the original layout unles it was an original show car
Once done I think you wil like it
Now the center stack looks old
The dash is perfect
The dash is perfect
#470 Re: The 5 Speed is here……..
Okay
I relent…..
So many DEATH threats from life long E Type buddies to suppliers…..
Everything just about fits!
I need to massage an eighth of an inch here and there
But yes it fits….
I was going in another direction THEN
Last nite NORMAN came down and said
“ Joey I supposedly did 150 in that car”
You can do it!!!!
So it will look stock except for the 5 on the shift ball
Gtjoey1314
I will explain what I did once it’s complete!
Give me a bit
I relent…..
But yes it fits….
You can do it!!!!
Gtjoey1314
Give me a bit
#471 Re: The 5 Speed is here……..
Amazing, you did a great job and Norman is smiling down on you
Although, I was looking forward to a custom interior, death threats aside......
#472 Re: The 5 Speed is here……..
#473 Re: The 5 Speed is here……..
Looks decent enough
#474 Re: The 5 Speed is here……..
Ohhh Hi !
I’ve got friends again!
I have to make the center stack clear comfortable to open the center console!
That’s all that’s left
It’s wonderful
I will format the whole thing once it’s buttoned down
Gtjoey1314
It’s wonderful
Gtjoey1314
#475 Re: The 5 Speed is here……..
Easiest solution to the centre console is to use a couple of thumbscrews to hold the switch legend rather than screws. Means you can remove the legend and drop the centre console in seconds. Available here: https://shear-loc.com/products/thumbscrews/
#476 Re: The 5 Speed is here……..
Lost you on the Thumb screws?
I have the two up top
I use Philips screws on the sides
I have to massage the double lip on top of the radio console
Will have pics tonite
If all goes to plan
I’m
Done and will have the whole
Do’s. And. Dont’s
Of this job, well with close to 500 miles in two weeks break in
She is quiet as a mouse in all gears and 5 th is a dream
Gtjoey1314
If all goes to plan
I’m
Do’s. And. Dont’s
Gtjoey1314
#477 Re: The 5 Speed is here……..
You don't have to massage anything. As Heuer has suggested , the easiest way of solving the problem of clearance between let down flap and radio etc housing is to replace the vertical screws which secure the plastic legend strip to the let down flap from underneath with thumbscrews . It is then a matter of about 20 seconds work to unscrew the thumbscrews, remove the legend strip and its backing, thus leaving sufficient clearance for the letdown flap to be lowered without disturbing the radio console ( and it's about 40 seconds to reverse the process )
#478 Re: The 5 Speed is here……..
Now I understand , My problem is once you releather everything the quality is so much better it takes up room.
Tonite i will have it done, no one will know......
Thanks for the tip.
I understand now.
GTJOEY1314
Thanks for the tip.
I understand now.
GTJOEY1314
#479 Re: The 5 Speed is here……..
I have to Thank You guys!
All these years with the dash I never thought of the knurl screws
It’s a great idea
Thanks again
Gtjoey
It’s a great idea
Thanks again
Gtjoey
#480 Re: The 5 Speed is here……..
Hi do you happen to know what size thumbscrews are needed, they have loads available ? ThanksHeuer wrote: ↑Mon Oct 17, 2022 11:14 amEasiest solution to the centre console is to use a couple of thumbscrews to hold the switch legend rather than screws. Means you can remove the legend and drop the centre console in seconds. Available here: https://shear-loc.com/products/thumbscrews/
Darryl
